Good...I'd hoped you wouldn't have a gun.
I thought you'd have had the 9:39 in any case? Are there any more extreme ratios? Tell me more.
Hi Peter, yes I do have a gun and I do have a 9:39 diff too, but the web is a wonderful place to while away your time and look up daft things like diff ratio's
Anyway the range of replacement diffs can be put into two distinct groups - higher ratio and lower ratio. The lower types seem to be available for close ratio applications of which I will pass !!
If we take my tyre size - 165/60R12 and add a 5th ratio to the box of 0.742:1
the figures for mph in 4th and 5th at 4k and 5k rpm with a change of diff are as follows -
standard diff - (8/39) @5k rpm gives in 4th 69mph in 5th 81mph
@4k rpm gives in 4th 55mph in 5th 65mph
BIS diff - (9/39) @5k rpm gives in 4th 78mph in 5th 91mph
@4k rpm gives in 4th 62mph in 5th 73mph
Hi Ratio - (9/38) @5k rpm gives in 4th 80mph in 5th 94mph
@4krpm gives in 4th 64mph in 5th 75mph
Hi Ratio - (10/39) @5krpm gives in 4th 86mph in 5th 102mph
@4krpm gives in 4th 69mph in 5th 81mph
So, it will be noted that the same speed can be gained from a four speed box utilising a 10/39 diff at 4k rpm as at 5k rpm with a standard diff and 5th gear.
As the engine is running much slower reliability should be greater.
What must be understood is the ability of the engine to 'pull' a higher ratio at lower speeds, the engine must be able to give more torque or remain inside the workable torque band sufficient to remain drivable. The gearbox reliability should remain as normal providing the extra torque from a tuned engine does not overcome the components. The approx cost of a pinion and crown wheel is the same as a 5 speed mod - where did I put the cheque book
Ian.
