im Axle Specialists
Old 12-11-2019   #1
USA
Smaller Gas tank option for the 500L ??
Half the size would be great......want more storage. Can't leave any bags visible in the car in San Francisco, it will get stolen.
Is there a direct fit option? Not interested in having one custom made, I don't want it that bad.
jtrashy is offline Reply With Quote Quote
Old 12-11-2019   #2
Re: Smaller Gas tank option for the 500L ??
There is no 'small tank option' for the 500L. However, what might get you round your problem is to see if one of the 'square' fuel tanks from an earlier model could be made to fit. They only occupy one side of the 'under the hood' area.
the hobbler is offline Reply With Quote Quote
Old 12-11-2019   #3
The tank that I had in mind comes from a 500D---the tank and the sender unit are both available from 'Van de Laan 500' in Holland.
Likes jtrashy liked this post
Old 12-11-2019   #4
Quote Originally Posted by the hobbler View Post
Believe it or not the N, D, F/L/R tanks all have the same capacities....
4.6 Imp. gallons, 5.5 U.S gallons. 21 Litres
I think the shape change was just to try to maximise the under bonnet space...
(I originally thought the N had a much smaller capacity..)
Bigvtwin996 is offline Reply With Quote Quote
Old 12-11-2019   #5
USA
Quote Originally Posted by jtrashy View Post
It really would be almost no effort for a decent shop to just cut yours and resplice it to take up less space. It'd be a couple cuts and one weld.
JumpJet is offline Reply With Quote Quote
Old 13-11-2019   #6
I am aware Peter that the capacities are the same---the reason that I suggested the 500D tank is that its shape might make it easier to stow a bag in the front--by having the tank over to one side, you are left with the whole right hand side clear.
Old 13-11-2019   #7
New Zealand
I have attached an image of the D tank setup. Still very little room for a set of golf clubs....Click image for larger version
Chrismunn is offline Reply With Quote Quote
Old 13-11-2019   #8
Patinated Peter
fiat500's Avatar
fiat500 has donated!
Quote Originally Posted by Chrismunn View Post
I have attached an image of the D tank setup. Still very little room for a set of golf clubs....Attachment 204427
Diverging from the original question (nothing new there!), do you think that 2 x "D" tanks could be fittted side by side?
fiat500 is offline Reply With Quote Quote
Old 13-11-2019   #9
New Zealand
It would be extremely tight, not sure why you would want to do this.....
Thanks fiat500 thanked for this post
Old 13-11-2019   #10
Patinated Peter
fiat500's Avatar
... I wonder about that myself.
It's just that for a long term "plan" I have in mind it would be helpful to carry more fuel.
Old 13-11-2019   #11
Quote Originally Posted by fiat500 View Post
Ahhh taking the "Rally look" further ... as per the Mini Cooper Twin tank setup...but sometime ago you posted a picture of your "under-bonnet", with the funnel, trolley jack, the tool chest, plastic sheet, traffic cones would there be enough room for a second tank....
Would you then cut some holes in the Bonnet and fit "Monza" style filler caps...?
They may just fit, but would be very close....
(PS I do have a spare D tank..... in case I decide to upgrade an N to look like a D)
Old 13-11-2019   #12
I thought you would probably be aware of the capacities but I think many people think the tank shapes were to increase fuel capacity....
As Jumpjet has said it may be easy for a shop to knock something up...
If you look at at the N "Flat tank" you could make something similar and slimmer from alloy by bending a sort of air plane wing section that fits between the front inner arches...
there would only be 2 welds, the sides and the front edge, being flat you would still have the space below the front panel and between the tank and bonnet...
Take a look at an N tank for the shape, I'm sure you could find someone with an N tank to draw round for the shape...
Something I have looked at to create more under bonnet space was to change the battery..... rather than have a single battery, I have looked at the small compact race batteries for Motorcycles, or even std Motorcycle batteries... and create a battery tray sunk under the rear seat area...
This would not only create more space behind the front panel, but also move the weight so it is between the wheels rather than over the front end..
Old 13-11-2019   #13
Still diverging but, Steyr put 2 'D' tanks next to each other for their 650 TR2 race model so could be an option for you.....
Likes fiat500 liked this post
Craig16 is offline Reply With Quote Quote
Old 13-11-2019   #14
Quote Originally Posted by Craig16 View Post
Now you are giving Peter ideas!!!!!
Gull wing doors next so he can get in and out easier!!!
Old 13-11-2019   #15
I had considered fitting a modified fiat 126 tank under the rear seat to add some extra capacity without compromising on luggage space.
I have a spare 126 tank, I should take a look and see how close it is to fitting.
MOD500 is offline Reply With Quote Quote
(T) Gas tank filter in the tank! vagosofron Grande Punto 14 16-11-2010 18:08
(T) gas tank removal dbith57 X1/9 2 25-01-2010 16:49
(T) Gas tank ID Kickstarter 124 Spider (Classic) 3 12-05-2006 04:23
