Gents,
I'm working on a minor lighting mod to install a third/center brake light behind the vents of the upper engine crossmember. My plan is to use the middle four to six vents and put vertical LEDs behind them that are attached to a motorcycle flasher so they flash rapidly upon brake initiation prior to going solid.
By putting it behind the vents, it should look fairly clean, yet still help with visibility.
I was wondering if anyone has pictures of the backside of that crossmember panel or pictures of the space behind it? I'd prefer to not have to remove mine right away and was just looking for some initial steers.
If I can get something fabbed up, I may go the 3D printing route and produce a couple if there's interest.
Thanks in advance!
Thanks in advance!
