Thread Tools
Old 23-10-2019   #1
USA
Repairing center heating tunnel
Hello again. Working on a 500F and noted significant rust damage to the center heating tunnel as well as the floor section that it covers. Before I start, is there anything I should be careful with when cutting into the tunnel?
I did remove all of the parts attached to it, as well as the all the cables, fuel line, etc. that run inside it.
Grateful for any advise; thank you!
myoshik is offline Reply With Quote Quote
Old 23-10-2019   #2
USA
Re: Repairing center heating tunnel
That is a great question. I just re-did my interior carpeting and noticed a lot of dirt, dust, grime, some rust in the tunnel. Its too bad there isn't a way to remove it, without cutting it out. Or at least I didn't see a way.
If you have all the cables and fuel lines out, then I would think you are in great shape to dig right in and cut. I don't see anything else really attached to it.
Thanks myoshik thanked for this post
1970 Fiat 500L
2001 Porsche 996 Turbo
tminus3 is offline Reply With Quote Quote
Old 23-10-2019   #3
Be aware that the central tunnel does contribute a fair bit to the car's stiffness. You must therefore make sure that you have added some bracing to the cars structure before you cut out the central tunnel
the hobbler is offline Reply With Quote Quote
Old 23-10-2019   #4
USA
Thank you for the response. Yes, the previous owner used self-tapping screws and some sort of adhesive to hold down the carpet. I didn't notice this so when I pulled the carpet, it took pieces of the tunnel with it.
I wasn't aware that the tunnel was a structural element, but it makes sense. Now I'm worried that my car is misaligned. I was hoping I could get away with replacing it without any braces, but I guess I have bigger problems now!
Old 24-10-2019   #5
USA
Instead of removing the whole thing, can you strategically cut portions of it and weld in fresh pieces of metal? That way you preserve most of the integrity of the car.
Likes myoshik, fiat500 liked this post
1970 Fiat 500L
Old 25-10-2019   #6
USA
I'm not really sure. I thought it might be easier to replace the whole thing instead of welding several smaller panels.
When I pulled the carpet, the section between the starter/choke lever and hand break broke apart. After I stripped everything, I used the air chisel and more of it started to come apart to the point where there was very little material left to hold up the starter/choke lever so I immediately stopped. The floor and the floor reinforcements looks to have been replaced recently, so I thought I could safely cut out what's left of the center tunnel, patch the area under it, and weld on the replacement tunnel.
I thought the rockers and the floor reinforcements would be able to take most of stresses, but I have never cut into a transmission tunnel on a unibody car and I'm FAR from an expert. I'm going to leave it alone for now and first figure out how I need to brace this. Always grateful for any advise/comment/etc...
Old 25-10-2019   #7
Patinated Peter
fiat500's Avatar
fiat500 has donated!
Quote Originally Posted by myoshik View Post
Sean @Franko500 is the expert on this and even had a new one fabricated and then welded it in before they became commercially available.
I've dealt with some very rusty 500's so would be surprised to see an unsalvageable tunnel on a salvageable car, but I'm regularly being taught things.
The tunnel is definitely made from heavier steel than most other panels and relies less on pressings and more on this basic strength than the rest of the car. I would avoid removing it and patch in carefully as you go, as recommended by @tminus3. Someone with reasonable skills should find this quite straightforward and be able to do a good job of tidying the repairs. As a monocoque, in theory all parts are of equal importance to the stability of the shell, but I think that removing the tunnel without having the car fully supported on a jig would be a very unwise thing to do.
The floors can be removed completely, if you tackle one side at a time, and although this does cause some flexibility and obviously affects the stability of the shell, as long as the sills and tunnel are attached at both ends and are continuous despite being corroded) I find that if you take care and keep everything level, the car remains dimensionally stable.
Likes myoshik, tminus3 liked this post
fiat500 is offline Reply With Quote Quote
Thread Tools
Fiat 850 central tunnel heating pipes La850diPeppino 850 0 29-07-2018 19:01
(T) Repairing center body piece YoniNijs Stilo 4 13-01-2012 12:21
Panda (Classic) Center caps (center of nuts, 2wd) Most Easterly Pandas Auction Watch 0 12-07-2009 02:29
(T) Heating of Transmission Tunnel. yengulamit Uno 2 18-06-2009 05:11
Dartford Tunnel activematt Leisure Lounge 4 13-06-2006 09:37
