Not so much an update as a vent. Having exhausted my limited fault finding talents and trying all the suggestions I have been provided with here I still can't get any life out of Barry (or Satan as he may now be known after today). I have fuel, I have spark and I have correctly adjusted tappets. Nothing more than a faint pop now. At one time it would run on one cylinder.
So, I thought I should check the compression after reading Labman's thread and purchased a compression tester online. It showed up today so I removed the plugs, attached tester to cylinder, had the throttle wide open, brother in law ready to pull the starter. Nothing. Check and find the cable has parted company with the lever and disappeared inside the tunnel. I tried operating the starter by hand and got a reading of 75psi on cylinder 1. Not great. Attached the tester to cylinder 2 and tried again. This time the excess, recently single, cable that had come through the tunnel, after deciding to separate from the lever, was on the pull and tried hitting on the positive terminal of the starter causing a burning sensation until I managed to disconnect the battery - a few seconds. Now the traumatised (and recently new) starter won't work. So I haven't been able to get a reading on the 2nd cylinder, have a seemingly damaged starter, a rogue starter cable that needs replacing AND an engine that won't run.
Vent over, feeling better
