^^ I think Richenrygarcia misunderstood me.
I read all the posts and saw that the problem was eventually traced to faulty brake hoses.
The reason I suggested stripping the old master cylinder was to see what the internal condition was like - I know fitting a new master cylinder didn't cure the problem with bleeding the brakes so perhaps the OP assumed that there was nothing wrong with the original master cylinder. If he strips it, he might be glad he changed it.
Many people familiar with working on older cars, will not attempt bleeding brakes by the traditional pump the pedal to the floor method, instead using either pressure or vacuum bleeding equipment to avoid any risk of damaging seals should there be corrosion in the normally unused section of the master cylinder bore.
I always strip old components to see why/how they failed, plus it may help me understand how something works. I suspect that, nowadays, most people bin the old parts asap. I tend to hold onto old parts for some time - there may still be some life in the old part - might do as a spare - might get me or someone else out of a bind sometime. Might actually be better that modern replacements - e.g. ignition coils/ condensers :bang:. Might also serve as a pattern or template, even if just to photograph to show someone what you're looking for - much easier than trying to describe it.
As regards changing the thread to show that HIS problem has now been solved - no need, the thread will die a natural death. However, he shouldn't be surprised if some people continue to post suggestions or thoughts related to his original problem. We do this for the benefit of others not just the OP.
If in the future, someone does a search on a particular problem/topic, 'his' thread might be resurrected by them to ask for help with their similar/related problem. They will see all the info/suggestions posted on the original thread, PLUS any suggestions that were posted after the problem was solved, this might help them, as their problem might not be exactly the same as his or solved in the exact same way.
P.S. I wonder if 'Richenrygarcia' has cut open the faulty brake hoses to see what went wrong...… (we might all learn something
AL.
