Thread Tools
Old 15-06-2019   #1
Fiat 500 ecu
Afternoon guys.
I hope Iím posting this in the right place😬
So Iíve had my Fiat 500S for 2 years (14 plate, 1.4turbo) The blue&me and USB port has never worked and the odometer has always flashed. (My stop start also only worked for 2 weeks then just gave up, Iíve had a new battery in and same again, not sure if this is related) I never thought of the mileage flashing as a problem until Iíve read on these forums about fixing my B&M.
Anyway, took it to a garage to have a diagnostic ran as thought a proxy alignment would fix this issue. The guy runs the diagnostic, wonít allow him to do an alignment so he digs a bit deeper...
Finds an error message saying that a test on the radio is Ďmismatched/failedí (bare with me, I was only watching him so not 100% on what it was sayingí
He runs another test to try and reset the ECU but this fails also after multiple attempts and Iím told itís going to cost £300+ to fix this issue.
Feeling a little frustrated and wondering if anyone can offer advice as to why this has happened (maybe an accident?) and if itís actually going to cost me a back leg to fix or if there is another way?
Thanks!
Ginger3 is offline Reply With Quote Quote
Old 15-06-2019   #2
varesecrazy has donated!
Re: Fiat 500 ecu
Hi.
Youve posted in the OLD 500 section.. but it will get moved.
Member @typecastboy may well have seen similar with the 500 repairs and tebuilds he has undertaken.
Any idea which device the garage was using? As the written explanations of issues ( error codes) can vary..
Charlie
Old 15-06-2019   #3
Quote Originally Posted by varesecrazy View Post
Hi.
Charlie
Iím thinking it was an Autel Maxisys that wouldnít allow him to reset anything. He did try with another device before but wasnít getting anywhere, that but I couldnít tell you what that was.
Thanks for the reply!
Old 17-06-2019   #4
Re: Fiat 500 ecu
Blue and Me Modules are not car specific. As long as you get one from the same age of car it should work fine. There's obviously a problem with your module so I would imagine that's why the proxy alignment won't work because the body computer can't connect to it. There are plenty of them on eBay for under £100.
Easy, albeit a bit time consuming to do it yourself. I did a guide recently on here.
https://www.fiatforum.com/500/473718...e-me-unit.html
typecastboy is offline Reply With Quote Quote
Thread Tools
(Tu) Fiat 500 1.2 Remap ECU? Bigpowerjam 500 5 05-02-2014 22:43
(T) Fiat 500 1.2 ECU problems? 91gina 500 11 05-10-2012 11:33
