Thanks for all the advice offered on purchasing a 500. I'm now the proud owner of this beauty.
Drives very well. Having been imported into the UK a few years ago and only having done about 370 miles in that time there are very few problems. I did a 40 mile drive into Sussex from London and it was great fun.
The only problems are the doors needing a good slam to close fully. Unless you continue the pressure when doing the shutting motion the door seems to bounce off before the mechanism can fully engage and it only half shuts. The other problem is the clutch being a bit sticky in 1st and reverse.. It only seems to be a problem when the engine is cold and makes it difficult to drive without lurching around at slow speeds.
Being in London and having no technical experience of these cars I'll probably drop it into Proietti for the clutch. Hopefully just needs something simple done.
I do plan on learning to do some maintenence myself so could take a look at the doors. Is this a common problem with 500 doors?
