Technical Engine puffs when releasing gas pedal
gordinir8
Established member
Athens
I always had this problem even from my 500cc days. Same with the 650, became louder when i put my sporty exhaust and even louder when i wrap the exhaust with titanium insulation because the pipes are running hotter now. Ok it might be fun, people thinking something big is coming but then:eek: Do you have similar issues?
Thomas
Just recently I started to get a bit of this when going downhill with foot off the gas. After reading up on it I decided it was insufficient air, with the throttle on minimum but a bit of forced fuel induction with the engine having to go fairly fast with little load.
So turning up the tickover screw a bit to let in some air seems to eliminate the problem.
Peter you mean the screw with the spring or the small idle brass screw?
Yes i have done it just to have better cooling and I saw some improvement. I also reduced advance a little. I think it is acceptable, besides little car sounds like a beast with my sports exhaust on!
