SpyderJava
Member
I am trying to see if we have a comprehensive list of all the light bulbs for the 500. I am wanting to upgrade my lights to LEDs for most of them, however I do not know the correct bulb sizes. I recently acquired the "Lexus style " halogen upgrade kit and the side turn signal lights did not come with a bulb, and they have 2 terminals on the base vs my cars original one terminal. Now I believe the other terminal is a ground so should be easy fix there. I also tried to hook up my new front turn signal lights and when I did the flash started to get a bit off. In cab indicator flashed quick and would stop. I narrowed some of it down to the fact the new bulbs are dual filament and my original ones are single with the indicator light being housed in the headlight. I'm just not sure how I am supposed to wore up the new turn signal as it has 3 terminals for a dual filament. assuming one is for ground, then where do I hook up the other wires? I will attach pictures that might help explain. The only wiring info I got was the translated instructions for the relay.
Photos in link:
https://app.box.com/s/lkfret202o6s5vb2rutkipwi4c5m31uw
Photos in link:
