timgarman
Established member
Hi Folks
Have just purchased an aluminium rocker cover and I've noted comments on the forum about fitting etc.
However, how easy should it be to remove the original? All the nuts and washers are off and I've loosened the ones holding the FZD. Also the one holding the tin cover thermostat top. But the rocker cover doesn't want to budge.
I've tapped it a few times with a hammer and tried to lever under the lip. Have I missed a fixing anywhere or is it just fused down?
I thought this should just pull off. Any tips?
Tim
Tim
