Strada Bianche
- Dec 30, 2016
- 35
- 12
Hi There, I have a Fiat 500F (1970) with a 126 652cc engine and Magneti Marelli alternator. The alternator was reconditioned unit fitted when I rebuilt the engine.
All has been fine for the first 1500 miles but yesterday the battery started emitting a rotten egg smell and the battery became quite hot,. I understand that this could be a dying battery or the alternator is suppling too much voltage.
To be safe I have replaced the battery (Yuasa) and when I measure the voltage from the alternator with the engine idling it reads 14.85 volts which seems too high but I have seen somewhere on a forum that a 126 alternator should give between 14.4 and 14.8 volts? HOWEVER my regular and trusted mechanic says that modern batteries should only see between 13.5 and 14.3 volts, any more and things will go wrong!
I am trying to find out what the correct voltage from the Magneti Marelli alternator should be (as its a modern battery I am assuming it should be the lower range 13.5 and 14.3 volts)
My Scenarios are;
A. 14.85 volts is correct and the battery has just died.
B. 14.85 volts is too high and has fried the battery (voltage regulator died)
Im not sure if the voltage regulator can be easily adjusted to lower the charging voltage? It may be just bust but before I get a replacement voltage regulator I thought id ask the people who know... ie you guys and girls!
any ideas gratefully recieved!
Many thanks.
My Scenarios are;
Many thanks.
