The white plastic bushes in which the release arm pivots are something I habitually replace when the gearbox is stripped-down; this the third one I've done so thoroughly. I can't remember finding the same situation as in this recent example where there is no bottom bush. The bottom of the shaft simply turns in the aluminium casing. It's very annoying because there does seem to be more play than I would like. Even if there is enough metal to allow it I'm not sending it away to be bored out to fit a bush at this stage. :bang: I've just looked at a 500 box and that seems to have two identical bushes. The one I'm dealing with is probably off a 126. Has anyone any idea if all 126 boxes are like this?
