Thread Tools
Old 05-12-2018   #1
Patinated Peter
fiat500's Avatar
fiat500 has donated!
Power to weight ratio in little Fiats
I am constantly surprised at how capable the 652cc engine is when transplanted in a Fiat 500. It surpasses all the encouraging recommendations that I had read before fitting it.
I was looking through the relative specifications of the cars, (actually doing even more research on my pet-subject of ignition advance) when I came across the power to weight ratios. So I did a quick calculation and then worked out the figure for a 500 with a 652cc engine:
500 with 479 engine: 23.4w/kg
500 with 594 engine: 25.1w/kg (NB. with factory fitted carb)
500 with 499 engine: 25.4w/kg
126 with 652 engine: 29.2w/kg
126 with 594 engine: 29.3w/kg
126 ELX 652 engine: 30.0w/kg
BIS with 704 engine: 30.04w/kg
500 with 594 engine: 32.4w/kg (NB. with 126 carb. and head)
500 with 652 engine: 33.6w/kg
So little wonder that my car goes like a rocket!!! It has a better than 30% increase on power to weight ratio in comparison with when it had the original engine fitted.
I am aware that the power to weight ratio might be seen as a crude comparator for performance and there are lots of other factors that could be taken into account. But for me this is an easy way to look at how different the performance between the cars is.
Terms and conditions: (must be read unfeasibly quickly )Please note: all of this data is taken from or calculated with data taken from other websites and stands to be corrected. There are many variations from year to year in the specifications for the 126 so these figures may not apply to all models.
Likes IanEmery, SDHXIII, Toshi 975 liked this post
fiat500 is offline Reply With Quote Quote
Old 05-12-2018   #2
Re: Power to weight ratio in little Fiats
Highlights the benefits to be had with a 500R if you fit the 28IMB carb to replace the original restricted 24IMB unit
Likes lazylobster, fiat500 liked this post
Toshi 975 is offline Reply With Quote Quote
Old 05-12-2018   #3
Patinated Peter
fiat500's Avatar
Quote Originally Posted by Toshi 975 View Post
..........plus, I think you once said that the cylinder-head has a narrower intake port?
Old 05-12-2018   #4
Quote Originally Posted by fiat500 View Post
......500 with 479 engine: 23.4w/kg......
I think 23.4w/kg is more than enough to achieve 30mph eventually.....
any more should have a requirement of a man with a red flag walking infront
Likes fiat500 liked this post
Bigvtwin996 is offline Reply With Quote Quote
Old 07-12-2018   #5
Ireland
^^ Even the old Citroen with only 2 HP could make it up a hill.
I know, I did it once.
AL.
If what I write is helpful please click on the 'thanks' button, (smiley face on lower right).
F123C is offline Reply With Quote Quote
Thread Tools
(T) Gear Ratio's TurboCinqy1250 Cinquecento / Seicento 33 17-01-2006 14:08
Increasing power to weight the easy way DaveP Lets Talk FIAT 2 12-08-2004 08:57
