Greetings, work at the swop shop continued today for an hour or two sorting another problem with the studs on the alternator fan belt hub, two are just acceptable, but one is beyond saving so I've sorted a replacement hub from mr E. Bay and the remaining studs and hub can go into the spares box
The fan housing was another trial as you would think that 'if it comes off another engine it will fit on the new one' ??
NOT!!! What a game it was getting all 9 bolt holes lined up !!! I began to think that I had done something wrong during the build so far - it just would not line up. I then thought what's the other engine like??? Aha !!! the little lower location dowl for the alternator mount had been removed - very cunning
So I just did the same - carefully, and hey presto it all fell into place all bolt holes lined up :worship::worship::worship:
next the sump mod and the timing cover - fingers crossed!!
Ian.
Ian.
