- Apr 1, 2017
- 361
- 137
2 more suppliers for you---"FD Ricambi" and "www.capassoricambi.it"
Jesus!...….didn't realise the performance side of these little things was so big...…….
Mod 500's post regarding the head studs is valid, but I am informed that given that dome nuts are fitted the turbulence is not too great unless you want hi flow hi output using bigger valves and a faster cam. QUOTE]
I should have elaborated on my comment. I think the head stud issue on the Panda 30 head is one of the reasons why the aftermarket ones have the inlet ports further apart. It would be an easy problem to overcome if you are designing a new one.
I have seen those push rod tubes for beetles. I like that they are threaded to adjust rather than sprung. Are they good quality? I was hoping to get a set for my build.
Hi Mod, Yes I agree the problem with the studs can be overcome, but I am concerned that the otherwise short studs must be even shorter to fit under the modified manifold and they don't look easy to get at either The tubes came from 'Megabug' the lads there are most accommodating. I can confirm that they are good quality, it's a shame that they need shortening to fit the Fiat engine. Make sure that you get a set of the large orange seals too as they are very robust and are a very good fit into the crankcase with a slight fiddle on the head end. I will be using a larger o ring on the threaded end as an oil seal, the supplied one is a little thin!!!!
Ian.
Ian.
I can confirm the MegaBug lads are a good crew, I have bought loads from them in the past (and no doubt will buy more)
Have I not seen these on Fiat sites though for the 500? why buy VW ones if there are fiat ones out there? (it may have just been in one of many weird dreams though)
Rob
Rob
Morning Rob, One of the rather irritating problems with the 500/126 engine is leaky pushrod tubes The only proper replacement Panda head tube (the lower portion) is very expensive and like most others available rely on a spring to maintain good seal contact at each end. With a simple set of mods the VW tubes will fit, but the main advantage is that they can be manually adjusted up tight and if they leak can be removed if necessary without taking the head off and new seals fitted if required.
Ian.
Ian, how do you use that Plastigage on a main bearing; these slide over to fit rather than being clamped.
Would that not be the tolerance allowed for the flow of oil around the bearing during driving conditions?
I once was trial fitting parts together before a true assembly using engine building paste/grease and thought a set of big end were wrong but after a few measurements it transpired everything was ok. I then trial fitted them together again with a good slurping of engine oil and it was like they were different parts...…..
