I noticed a useful lengthening of the gears when fitting the gearbox from a 126 and this uses the additional power of the bigger engine whilst keeping the high rpm reasonable at speed. Putting aside the fact that an everyday engine may not work well with the BIS crownwheel and pinion, does anyone know if the difference it makes to comfortable top cruising speed is in the same order of magnitude as going from the 500 to the air-cooled 126 setup.... someone was asking me.
Hi Peter, If you put together a list of later 126 engine output figures you get the following -
595 engine 23bhp / 17.1511kW
652 engine 24bhp / 17.7kW
BIS engine 24.8bhp / 18.5kW
Panda 30 30bhp / 22.371kW
so the jumps between the stages are not great for standard engines. Unfortunately I cannot comment about a standard comparison as my engine has 30+ bhp.
The difference in overall performance will depend on the tyre size, and the gearbox ratio's fitted from the standard.
To give you an idea of the differing speeds between the 8/39 and 9/39 differential with the 126 gearbox you can look at the following site (this is not exact but close enough) look at the 'westfield-world kit car support site' at the top of the page go to 'tools' and select 'gearbox ratio calculator' from the dropdown. Input tyres, diff ratio, gear ratio, and the format of display mph/kph. The diff ratio for the 8/39 is
4.875 and the diff ratio for the 9/39 is 4.333
see what you get. I have to say that after fitting the 9/39 diff my speedo underreads slightly, and the car cruises at a much more comfortable rev point 50mph is achieved at just under 3500rpm - I think
if you need any more info get back to me.
Ian.
