nathanrobo
Member
Thought it might be interesting to do a thread on upgrading the headlights for a 500. I'd appreciate any expert critique ;-)
The loom that comes with the Kit (as sold by Axel in Germany & Frank in Holland) doesn't appear to make a great deal of sense, it's certainly not plug and play. You'll need some 6.3mm terminal connections, spade & female with shroud's. I used bare terminals with push on shrouds as they look more original than the insulated terminals. But it does mean using a different crimping tool - I'll post pics of the crimp tools etc tomorrow:
But wiring the system is fairly simple.
There's one relay for each side High Beam, with dipped beams (possibly) connecting directly to the switches (I need to check) Note: 500's are wired with Left Hand Headlamp to rear right light etc).
I bought ceramic H4 headlight plugs.
Left Highbeam
1. You need to take the wire Black / Green from the switch on the stalk. Connect it pin 86 on the 4pin relay & connect a grounded earth to pin 85 - these are the two sides of the coil windings on the relay. When they are energised they close the "normally open" switch in the relay. In practice you will be taking the 3pin plug from the back of the light and using the Black / Green wire.
2. Connect Pin 30 via a fuse to the battery and pin 87 to the wire high beam wire on the light itself. So when the coil is energised by the Black / Green coming from the high beam switch, Pin 30 (live from the battery) and Pin 87 to the bulb are connected together.
Picture below shows the wiring diagram for a H4 bulb / plug (this is a different arrangement vs. the original bulb / light)
3. Test that the left high beam works.
Right Highbeam
Repeat point 1, 2 & 3 for the Right hand light (solid green high beam).
As mentioned above I think the low beams can be connected directly to the switches (I haven't done the low beams yet), but it might be preferable to get a pair of fused relays and connect the low beams (left and right separately).
Low Beam Left hand side on Relays:
Black / Grey from switch would connect to 86 on the relay, 85 would be to ground, 30 from the positive on the battery and 87 out to the bulb via the back of the H4 connector plug.
Low Beam Right hand side on Relays:
Left Highbeam
Right Highbeam
