Thread Tools
Old 10-10-2018   #1
Australia
Replacing rear axles / driveshafts. Help needed
Hi
Has anyone taken pictures of the driveshaft removal from the diff centre?
Dismantling gearbox and removing replacing axles?
I have tried searching the forum but if there is a thread you can point me to that would be helpful as well
Geoff
1500500 is offline Reply With Quote Quote
Old 10-10-2018   #2
Re: Replacing rear axles / driveshafts. Help needed
This is all I have Geoff. Donít know if they are any good to you?
Tony
ID:	194721   Click image for larger version
ID:	194723   Click image for larger version
Likes 1500500 liked this post
Vitesse is online now Reply With Quote Quote
Old 10-10-2018   #3
Hi Geoff;
Sadly,according to the manuals that I have (and 'Haynes' gives quite a clear description) you do have to remove the complete diff unit and strip it. I f you are very canny, carefully mark where all the adjustments and adjusters are set prior to stripping the diff, and then, after you have replaced the shafts you should be able to put everything back together 'as was'. If you want, I can copy out the appropriate pages for you and post them to you.
the hobbler is offline Reply With Quote Quote
Old 10-10-2018   #4
Greece
Here is a nice guide with pictures ofcourse advice manual first.
https://www.flickr.com/photos/ricamb...57615692546231
gordinir8 is offline Reply With Quote Quote
Old 10-10-2018   #5
Australia
Quote Originally Posted by gordinir8 View Post
Thanks. Thatís exactly what I was after. Cheers. Geoff
Old 10-10-2018   #6
Australia
Quote Originally Posted by the hobbler View Post
Hi Geoff;
Thanks Tom
I have a Haynes manual that I should dig out. I looked at my Originale Fiat manual earlier today
I also spoke to a local mechanic who said the same as you. Mark all of the parts and all should be ok.
Geoff
Old 10-10-2018   #7
Australia
Quote Originally Posted by Vitesse View Post
Tony
Thanks Tony. All of these pics will help.
Geoff
Likes Vitesse liked this post
Old 10-10-2018   #8
Thats the pictoral guide I used when I did mine. I did as Tom suggests and marked everything so it went back the same. I know youíre supposed to check the backlash but I didnít bother and so far nothing has gone bang. Your car though so its up to you
Paolo66 is offline Reply With Quote Quote
Old 10-10-2018   #9
USA
My link in Flickr has helped a lot of customers put the new driveshaft in place. I am happy that my Flickr link is still being used till today to help out a lot of Fiat 500 owners.
Thanks gordinir8 thanked for this post
Ricambi Fiat 500 is offline Reply With Quote Quote
Old 11-10-2018   #10
BambinoClassic has donated!
Australia
Quote Originally Posted by Ricambi Fiat 500 View Post
They are some of the best quality photos I've ever seen on a car diy guide, well done and thank you
( I also love the forced break in repair - have pasta now)
BambinoClassic is offline Reply With Quote Quote
Old 11-10-2018   #11
USA
Thread Tools
Are there any other rear axles compatible with the panda 2008? mantoszczak Car Care 1 16-07-2018 22:03
(T) Replacing Tipo Rear Subframe Rear Mountings yaztaz Tipo (Classic) 26 12-08-2013 03:20
(T) Rear Axles meooo Cinquecento / Seicento 3 15-02-2010 18:09
(T) Anybody else's CD player needed replacing ? Chrisedmo 500 0 22-04-2009 20:44
(G) Panda rear axles ??? Pete Panda (Classic) 4 07-09-2003 17:45
