autocomman
- Mar 6, 2017
- 53
- 15
So on our 66 giadineria it has carello headlamps, 3 adjusting screws. Push and rotate the whole housing pops out of the car. this one is a EV co version so I put in some LED bulbs, and dumped the crappy old burned out bulbs. Well they suck, a lot. I cannot get em aimed low enough, the pattren is wierd. I know it's probably the LED bulbs, but what options are out there? I don't wanna use halogens. No inspection to pass here in the states either, but I gotta use lights that work lol. When they are I stalled also, the carello is readable bit they are slightly tilted. The flutes are not vertical exactly, they are a few degrees off.
Am I missing something with these? Other than the fact the bulbs may be not right for the housing. These have the separate base that holds the bulb, then the assembly goes on the back of the headlight, not H4 style at all.
