SpyderJava
Member
I've been having issues with my 650cc 500 R starting and running. I noticed today since it was dark out that I am actually getting a spark between the b+ terminal and the output to the distributor on my ignition coil. I'm trying to figure out what may be causing this, I'm thinking maybe points or capacitor in the distributor might be messed up and causing too much resistance back feeding the system or something. Spark plugs look fine so I dont think the issue is there. Maybe the coil itself? I had another ignition coil in there before and had no start issue so I dont think it's that unless both are bad. I have a 123 ignition kit on it's way anyways, but itll be here in a few weeks, and I would like to get it running in the mean time if possible. Anyone have a similar experience or suggestions? Thanks.
