Technical leaky oil pan drain plug
Uaglio
New York
In my last step to upgrading to my 650 engine, I quickly installed a 3.5 liter aluminum sump / oil pan (pictured below) to replace the 2.5 liter stamped steel one that came with the engine. It has a 10mm female hex head (allen key) plug flush on the bottom. In my haste to install it, I didn't even take the plug out and look at it first. I just slapped it on with new bolts and Permatex Ultra Grey RTV.
Now, after sitting a few days with oil refilled, I noticed it is leaking drops (8 cm puddle under the pan). It's definitely coming from the drain plug and not the top flange or the RTV seal. I gave it an extra 2 mm turn to snug it up the other day, but it's bottomed out now and still leaking.
Does anyone know the best way to stop it from leaking? I thought I read that a Locktite product might work, but I don't want to make it harder to get the plug out for future oil changes. I am not sure what other thread sealer is acceptable for a situation where it will be pretty hot. Is it supposed to have a crush washer on it? Because I stupidly put it on without inspecting it first, I don't know if there is a washer on it now. I'm not able to get to it for a few days, but if there's any odd size washer or gasket, I'll probably have to order it and would like to get that done so I have it when I'm ready to fix it.
Thoughts appreciated!
Does anyone know the best way to stop it from leaking? I thought I read that a Locktite product might work, but I don't want to make it harder to get the plug out for future oil changes. I am not sure what other thread sealer is acceptable for a situation where it will be pretty hot. Is it supposed to have a crush washer on it? Because I stupidly put it on without inspecting it first, I don't know if there is a washer on it now. I'm not able to get to it for a few days, but if there's any odd size washer or gasket, I'll probably have to order it and would like to get that done so I have it when I'm ready to fix it. Thoughts appreciated!
Hi Uaglio, it's a bummer but you will have to drain the sump (into a clean pan and then refill) take out your drain plug clean it with white spirit and either use a suitable fibre washer or try Plumbers PTFE thread seal tape, it comes in different sizes and is cheap to obtain. For the best job use both (y)(y)(y)
Ian.
It should have a copper washer under it. Mine leaked so I put some PTFE tape on the threads but I still get the odd drop. Think I’ll go for a dowty washer next
thank you gents. I'm going to try both a crush washer and thread sealant goop. I see a few manufacturers make stuff specific for oil plugs.
By any chance, would anyone know the inner diameter and outer diameter size of the plug washer?
Had the same problem so i drain it and use some red rtv but the problem is that the surface that the crash washer sits is untreated and not dead flat. I removed it and mill it down so now I am only using the crash washer and seals perfect. They had to machine it in the factory before release it for sale. I also opened the side hole and install a temp sensor.
Thomas
As others have recommended, use plumbers tape. I did it on the oil pan and the gearbox and it's almost completely stopped it from the oil pan.
