If the door shuts correctly (i.e. lines up with panels fore and aft) with seal removed, then door hinges and lock striker plate are adjusted correctly - problem is probably with the thickness of door seal being used.
Sometimes, the flange onto which the seal fits can be carefully 'adjusted' using a block of timber and hammer. Sometimes this is enough. (don't overdo it!).
New seals tend to settle down (i.e. collapse slightly) so may make the door hard to close initially but settle after a while.
There are different size seals available, especially with respect to the dimension of 'C' in gordinir8's post #17 above, as mentioned by Antgiu.
One source of door seals in different sizes is www.carbuildersolutions.co/uk/car-boot-and-door-seals
e.g. TRMDS - 9mm foam bead, TRMDES - 10mm hollow bead,
or you even even try TRMDRL - flexible sponge leaf seal.
www.woolies-trim.co.uk seem to stock only one size of car door seal similar to the dimensions of what 1500500 shows.
Another possible source for alternative size seals is a Car Retrimmer/Vehicle Body Builder if you happen to have one near to you (might help some avoid carriage costs/delay).
AL.
AL.
