FIAT Auto Specialist Team
Thread Tools
Old 2 Weeks Ago   #16
Australia
Re: Doors buckling when closing
Can doors be adjusted? If anyone has any tips Id love to hear them as my doors could use a tweek.
Bettegacci is offline Reply With Quote Quote
Old 1 Week Ago   #17
Greece
Quote Originally Posted by 1500500 View Post
I bought the Axel Gerstl thinner than original seals. When trial fitting my doors before painting they seemed to let the doors shut without too much pressure
https://webshop.fiat500126.com/en/ru..._-length-330-m
I have the same problem with my door seals and i have to slam them each time .Door without seals close perfectly. Can you take a measurement from your Axel's thin seal iaw the drawing i am attaching and give us the dimension A, B, C, D and Ε? so we can compare with what we have?
Thomas
gordinir8 is offline Reply With Quote Quote
Old 1 Week Ago   #18
Australia
Quote Originally Posted by gordinir8 View Post
Thomas
Here you go
A. 15mm
B. 10mm
C. 5 mm
D. 10 mm
E. 10mm
Geoff
1500500 is offline Reply With Quote Quote
Old 1 Week Ago   #19
Greece
Thank you very much although i think dimension D my mistake in the drawing. Most important dimensions are C and E. Now if C is only 5mm that is indeed smaller than the one i have now. Thank you very much, i might order a set to see how it will fit.
Thomas
Old 5 Days Ago   #20
Australia
Thomas
Oh
Im sorry Just realised I mixed up c and d as I measured each part as I went around the seal
Old 5 Days Ago   #21
Ireland
If the door shuts correctly (i.e. lines up with panels fore and aft) with seal removed, then door hinges and lock striker plate are adjusted correctly - problem is probably with the thickness of door seal being used.
Sometimes, the flange onto which the seal fits can be carefully 'adjusted' using a block of timber and hammer. Sometimes this is enough. (don't overdo it!).
New seals tend to settle down (i.e. collapse slightly) so may make the door hard to close initially but settle after a while.
There are different size seals available, especially with respect to the dimension of 'C' in gordinir8's post #17 above, as mentioned by Antgiu.
One source of door seals in different sizes is http://www.carbuildersolutions.co/uk...and-door-seals
e.g. TRMDS - 9mm foam bead, TRMDES - 10mm hollow bead,
or you even even try TRMDRL - flexible sponge leaf seal.
www.woolies-trim.co.uk seem to stock only one size of car door seal similar to the dimensions of what 1500500 shows.
Another possible source for alternative size seals is a Car Retrimmer/Vehicle Body Builder if you happen to have one near to you (might help some avoid carriage costs/delay).
AL.
Likes gordinir8 liked this post
If what I write is helpful please click on the 'thanks' button, (smiley face on lower right).
F123C is offline Reply With Quote Quote
Thread Tools
(T) doors not closing correctly amigo 900t pedalb0y 850T / 900 4 08-10-2015 08:01
(G) Doors open warning yet doors shut Adeyb123 Multipla 0 10-09-2014 23:17
(G) closing doors via alarm remote control pandalovah Panda 7 19-05-2007 16:00
(T) 3 doors side skirts >> 5 doors? giulio Tipo (Classic) 16 16-04-2007 20:29
Closing the loop davemarsh Site Ideas 3 07-05-2004 21:53
