Old 15-07-2018   #1
Testing low fuel sensor / light
Hi all, how can I test that the circuit, bulb for the low fuel indicator in the speedo. Is it a case of shorting the live red wire to the tank?
Be nice to now this works. To test the float mechanism, presume remove it from the tanks and manually activate it?
Rob
lazylobster is offline Reply With Quote Quote
Old 16-07-2018   #2
Re: Testing low fuel sensor / light
Hi
the red wire goes to the warning light.
A quick look at the wiring diagram shows that this goes through the sender unit and is then passed to earth.
So yes, with ignition on, short the red wire to a good earth and the light should come on.
Only need to take the sender unit out if there is a problem.
Likes g8rpi liked this post
Regards Sean
"con grande sacrificio, coraggio, pazienza, determinazione e qualche chilo e il sogno si avvera"
Franko500 is offline Reply With Quote Quote
(G) low fuel light M111CYY Punto (Mk2/2b) 10 13-06-2007 14:17
(G) low fuel sensor fault andy thrill Stilo 2 22-03-2007 12:02
(T) attention cmc ,purple monday ref low fuel sensor fault andy thrill Stilo 6 06-07-2005 23:29
(T) sensor fault low fuel slight return andy thrill Stilo 6 28-10-2004 11:28
(T) sensor fault-low fuel andy thrill Stilo 32 20-04-2004 05:21
