I'm trying to replace the old distributor in my 1971 500F with a brand new 123 Ignition, but there's a problem. The old distributor is stuck. I've removed the clamping nut, but the case won't budge. So far I've tried spraying with WD40, tapping it with a rubber hammer, and twisting/rocking it with just my hands, but it just won't budge. Other forums suggest using carb cleaner as a solvent to loosen the bond. I'll pick some up tomorrow and try that.
I don't see a gasket there so I suppose it's just corrosion or old coked oil holding it together?
Does anybody have any suggestions before I start applying more force?
