Just bought a Bambino a few days ago, 16 years after I lost my last one to an accident - (it dive-bombed a Landcruiser!!).
This Fiat was advertised as having an ABARTH motor but on seeing it there was nothing stamped Abarth on it.
I live near Sydney and found that on the way home, when it was running well, that it had considerably more ‘go’ than my old one with standard 500 motor.
This one has a 650 motor. ‘AK84M’ is stamped above the ‘650’.
It has ALQUATI stamped on the Carb manifold as well as ALQUATI stamped on the Sump.
The carb is a large Weber. Fo the very short time it ran well it showed a lot of power however it mostly backfired and cut out after every 15 to 20 kilometres.
I did a google search on ALQUATI and found very little except that Camilo Alquati was a Fiat Tuner. How do I check whether this motor is special rather than one with just a bigger carb, sump and a named manifold.
By the way it also has a special exhaust with dual pipes. So I guess it has a number of older bolt on stuff.
Is it rare or sought after or a run of the mill engine with some bolt on goodies. Interesting that it has 4 things that Alquati tuned ‘500’ had.
Thoughts??
Thoughts??
