Duckbreath
Member
- Sep 9, 2016
- 13
- 79
Bonjour: I have a 71 500l with a weber 26 carb, and electronic fuel pump. I have put in a new petrol tank, new fuel filter, new carb, petronix electronic distributor, new coil, new exhaust manifold, etc. I still experience what I believe is heat soak vapor lock, mainly after a longish hot run. Running with the motor cover open seems to help but not ideal. I was in Deal, UK recently for a car meet and spoke to a chap that had installed a weber 28 with a return line. He installed a T at the sender by the petrol tank, and ran the return from the back of the carb to that T. I also saw a pic here on the Forum from N Zealand, where the T was at the fuel pump and ran the short distance from the Carb to the T just before the pump. I plan on insulating all the fuel lines. Any thoughts out there if there is a prefered method, to install the T just before the the pump or do it at the tank, and have the return line there. Clearly the first method is shortly and easier, but is it as effective?
Thanks for all your help!
Living in France/California where the british iron rest: '51MGTD; '57MGA; '67MGB; '72MGBGT; '59Jag Mk 1; '61f-Fiat Osca; 50Jeepster, 911
