I've learnt a lot from this forum over the past 8 months whilst re-building my 500, but now I have my first question.
I have rebuilt the engine and set the static timing as described in the Haynes manual. Engine starts well and runs well so far (250 miles) I'm still running with trad points and condensor and plan to fit an Accuspark trigger.
Prior to fitting the Accuspark I decided to check the ignition advance using a Gunson strobe. With the tdc marker on the pulley painted white and the arrow on the timing cover painted white, I found that I had to set the Gunson advance dial to 40 deg to get the two marks to line up. I guess I was reving the engine over 3000 rpm. The book says 28 deg for max advance.
What are the group's thoughts?
Peter
Peter
