Technical No distributor !
TerryP
East Yorkshire
I have just installed a 126 EL motor into my 1968 500F.
The "EL" is the very last version of the 652cc air-cooled motor and has ... no distributor. The block casting is not even bored where the distributor normally fits. The ignition is triggered by a sensor next to the crankshaft pulley.
So far, although I have tried hard and long, I can not find any information on this system.
Can anyone please help me with a wiring diagram for this installation ?
Thank you.
Do a Google search for DIGIPLEX ignition and see if it looks like what you have.
That's all I have, I imagine someone more knowledgeable will come along shortly. Good luck.
I’ve got a fair bit of info in these too. Message me your email and I’ll send you all the info I have!
Chris
Chris
Thanks for all the replies.
Pod, My email is TerrysModelcars(at)aol(dot)com
Any and all info will be gratefully received.
Thank you, Pod500, for the info you emailed to me.
I'll let it sink in, then get cracking at the first opportunity.
