A guy has asked me to fit new piston rings to a set of used Pistons and install them along with conrods back into the used barrels. So after a clean up and a glaze busting job on the bores there is a tiny discernable wear step on one side of the bores, half a fag paper which I assume has been on the thrust face of the bore. Seems a good idea to assemble the Pistons in order that the thrust is now on the opposite side of the bore to balance out further wear. This will be determined by which con rod goes in which barrel. I have studied the diagram in the manual showing piston offset, direction of crank rotation and camshaft position and can't decide which is the bore thrust face.
