After starting this thread I must firstly thank all who have contributed then apologise for not responding sooner. I was delayed for a short time by a large snow drift that had built up against my garage door then during the thaw other priorities emerged. So the other sides of the Pistons , one is the same with the damage but the other one is perfect. The engine had been "repaired" and only covered that short mileage before nearly seizing up. The previous work included the fitting of a replacement conrod. When I checked it out the engine had one 500 rod and one 126 rod with 126 big end shells. So the piston with the 500 rod got no oil squirt on the bores at all. The other should have been ok but I wonder if one jet was blocked or the overheating affected the other cylinder. The engine had also been running with just over half of the correct oil level which would not have helped with any splash effect inside the crankcase. I wanted to get opinions on possible causes as I found the beginnings of similar signs on a piston from a slightly more exotic 795cc engine that I just stripped down pending a rebuild. The engine has been in store for over 30 years and had done less than 3000 miles so I want to use the original Pistons and barrels so when I have cleaned all the parts up I will be checking clearances and oil ways for sure
