Seasoned regulars of this Forum will know of the cyclical nature of queries which come up around here. I get the impression that for many new owners the unfamiliar layout of the machine and it's pre-1960's mechanical design is so different from what they are used to that there is a presumption that the car is complicated, fragile, unreliable and quirky.
I think it's a good time to point out that only that last adjective is true of the Fiat 500 and I suspect it to be the major reason why newcomers are attracted to them. As has been shown very recently, the chances are that even if you have bought one that looks good it will require quite a bit of "shakedown" before it achieves its full magnificence. Even when you have it perfect, whether you then use it or not it will gradually fall back into bad habits. So it will repay any owner to become familiar with and to relish dealing with all of the issues the car can present you with. Properly adjusted and maintained this is a superb car to drive around in; its attractions go far beyond its appealing looks.
It surprises me that a significant number of the issues that do get asked about relate to the engine performance. This means that most matters have been discussed in amazing detail many times and from many angles. I wonder if there is a way to create an editable, collaborative set of documents that bring together everybody's ideas and experiences on each of the issues so that the valuable explanations and solutions which have been given, that are somewhat difficult to distill on a "search", could be made into a set of "stickies"?
Maybe we need a Wikipedia entry?
