Quick question- is the gear shift lever supposed to rotate freely? I’m not talking about it being loose or rattly, just whether it’s supposed to be tight in one position rotationally. Imagine if the shift knob had a logo on it or a shift pattern. You wouldn’t want it to rotate (talking about the whole lever, not the knob), so that you’d need to frequently turn it back upright. Well if I had a logo knob, or printed shift pattern, that’s what would probably be happening to me. My shift lever Rotates, and I can’t detetrmine if there’s a nut on the bottom of the lever that needs tightening. Given its spring loaded design to allow it to be pressed down to access reverse gear, I’d assume it should be the way it is - turnable in either direction, but not loose.
I just want to make sure I don’t inadvertently spin off a nut at the bottom of the lever and have it come off while under way. I tried to look at it from up top, but couldn’t get a good look just by removing the boot and console.
