- Dec 10, 2017
- 158
- 37
Had a forum member contact me suffering withdrawal symptoms as I haven’t posted a picture for 24hours so this is for you Peter
Ok this weekend I’ll stripping everything down and shotblasing to see how many parts I can re-use .
In the picture my drive shafts have tin plates/cups that seem to be there to protect the Cush drive joints has anybody seen these before .
And also it appears that the car was a light green or blue colour in its previous life.
Never seen those "cups" before....Court calls for the Investigator :chin: :chin: PETER
I was hoping you was going to say you have a pair I can have :bang::worship:Never seen those "cups" before....
And I hope the wishbones are usable.... N only!!!!
It would look nicer in the earlier light colours....
Well with the prices of the parts I have sent you ...
Probably getting to the point of buying a car for parts...
of course there is the easy way out...
upgrade to the Modern later setup... but that wold be toooo easy eh!!
do those cups like factory or someone made them?..
No one I know has seen anything like them...
and nothing in any parts books I have..
mate has a NOS pair for £1500Those rear arms are totally different to the D or F/L
They have the bump stop on the arm instead of the bodyshell.
Also the handbrake cable bracket is in a different place.
Possibly those cups were to prevent dirt build up?
The D arms had 2 small lengths of steel welded each side of the arm, presumably to scrape any build up of dirt off the joints.
By the time they got to the later ones they didn't even bother.
Hi Andy,
I noticed a difference on your bootlid that I have not seen before.
How was the exhaust heat sink mounted to the inside of the bootlid?
All bootlids usually have these tabs on the inside that it hooks over.
Yours has 2 holes in a raised area. must be an early idea that they changed.
