Hi all,
I am restoring a 1967 Fiat 500, I am nearing the end, but one issue continues to haunt me and that’s me starter cable. I have a brand new one, run through the cable, through the impossibly hard to access clip by the gear box and then out to the lever on the starter.
Problem is the cable is slack, it’s on the nearest hole, but is still floppy. Only when the lever is up is there any kind of tension. If it makes any difference it’s a 650 engine and the starter is on the side.
My thoughts so far are :
A. There is another clip I need to fasten the cable to, this will get the tension (probably at the end like a brake cable on a bike)
B. It’s the wrong cable, and is for another 500 type which is 2” longer.
I have been through all the previous threads, but nothing really helpful apart from the ones on the hole for the clip, which were really helpful.
Any ideas would be great.
Will
Will
