I should have taken a few pictures of how the headlights lit up BEFORE I hacked up my headlight bulbs. I separated the dish-shaped mounting flange from my headlight bulbs and used them to mount LED bulbs that were supposed to be H4 compatible. They fit right in and seem to work OK. Problem is, I don't know how to orient them inside the headlight. They have LED chips on two sides. The way I have them now, the top half illuminates on low beam and they both illuminate on high beam. The pattern doesn't look good either way. I can rotate the bulbs and experiment with how they look, but can anyone tell me how the stock bulbs look? Do they illuminate the whole reflector or just the top or just the bottom when on low-beam?
Anyone else converted to LED bulbs? How are they oriented?
