the hobbler
Distinguished member
- Jul 25, 2012
- 4,084
- 1,013
This subject sort of 'hijacked' Ian's thread on problems with his gearbox, so I thought that we could give the subject its own thread.
I am in contact with a couple of colleagues who are Polish and carry out 500/126 business with their contacts in Poland, and have asked them to try to ascertain if 'Motomax' are still a viable company---I will advise the forum of the outcome of those enquiries.
A couple of questions to Andrew, who has already fitted the Motomax C/V couplings to his 500. (a) what size socket did you use on the nut--measuring with my micrometer, it would seem that the nut is 26.5mm(!) Did you use an Imperial sized socket, and if you did, can you remember what size it is (1-3/64ths?) and, (b) the effort required to tighten up the rear hub nut is quite considerable when it gets to the point that you are trying to 'crush' the spacer to get the correct pre-load on the bearings. Were you able to do it all with the new (relatively small, when compared to the 'normal'30mm) nut, or did you do the bulk of the tightening with the original setup (ally/rubber coupling and 30mm nut) and then fit the coupling and 26.5mm nut for the final pre-load tightening? Your input on this would be much appreciated Andrew. :worship:
