fiat500malta
- Oct 26, 2017
- 5
- 1
Good morning, just joined this forum
I have a problem with my 1967 fiat 500, it has a 595 engine with an upgraded cam and other small mods. I bought the car from Sicily a couple of weeks ago.
The problem is that the oil pressure light sometimes decides not to go off and remains alight. I removed the oil pickup pipe and replaced the rubber sealing ring and problem seems to have been solved as light was coming off immediately on starting, not flickering even when car is running at normal temp. Now I have the same problem again, no oil pressure.
The problem is intermittent, so I'm completely lost. Yesterday it was all fine and an hour later it just went off again. This is not related to the grade of oil as Im using 10W40 and oil is new. When I had the sump off, I also checked the crank bearings and they are practically new, crank was full of oil and everything in there is fully clean.
Did you ever encounter this problem? Can it be related to the pressure relief valve inside the oil pump getting stuck?
Thanks in advance.
Thanks in advance.
