Technical Wiring Diagram
GialloN
Member
Hi All
Does anyone have a Wiring Diagram for a Fiat 500 N - 1958?
Thanks!
I have a 'Pukka' (Factory) 500/500D workshop manual. looking at the 2 wiring diagrams there are a few differences (the various parts are labelled up differently). Where do you live; I am quite happy to copy out the 500 wiring diagram and send you a copy.(y):)
I am in Johannesburg South Africa
Do you still need a wiring diagram for your 500N?---as I mentioned previously, if you e-mail me direct with your address in Jo'Burg, I will put a copy into the post for you.(y):)
Go here http://www.tipo110.com/Images/ManRip_500N.pdf and download the whole Bible for the N, albeit in Italian. It's page 117 0f the PDF but heres ascreenshot which will probably be too low resolution to be useful.
The whole manual has amazing detail and I will be downloading it because there is plenty which will be transferrable to later models. I especially like the chassis dimension pages.
Hi All
Thanks!
I've just had a dig through the various books I've got and I think this is for an N:
This is the only diagram I can find that doesn't show both front side lights and wing repeaters so I think it should help you.
I can copy and post it to you if it will help you
Thanks everyone for the help. I have re-drawn the wiring diagram and added a bit of colour. I hope it helps other (y)
Ciao
  • Fiat 500 N - Wiring diagram Schema elettrico.pdf
Re: FIAT 500 Abarth Wiring Diagram 2009
FIAT 500 Abarth Wiring Diagram 2009 anybody have one or know where I can get hold of one?
^^^^ You posted this in the wrong forum. There's a forum for the 500 Abarth just above the forum for Fiat. Or you could post in one of the forums dealing with the 'modern' 500.
AL.
