Been having a clutch conundrum. Every time I adjust it it works fine for half an hour, then worsens until eventually dragging with the pedal fully pressed on the floor so as I can't cleanly engage a gear.
I'm going to change the cable and suspect that is the major issue (it's probably the original...). However, when I replaced the driveshafts a while ago, I noticed the clutch lever only had one plastic bush fitted in the upper position - you all spotted that in the photo didn't you?.
The lower position isn't big enough to take a bush and the lever shaft was a reasonable fit in the casing so that's how it went back together. Anyway, I need to replace a driveshaft boot as well and so thought I'd whip the engine out to give everything a check over (I replaced crank seals etc - seems dry now ) and have another look at the clutch.
So, whilst there's not a load of slop, I'm inclined to get a 19mm drill and open up the lower position, the challenge being to keep the alignment, easier if i can find a drill long enough to use the top bore as a pilot.
Anyone seen this before? None of the usual suppliers have. The other option is to source a replacement Bell housing but that seems a bit extreme. All a bit odd....
If anyone has a long 19mm drill you might lend me I'd be very grateful too!
