Thread Tools
Old 4 Weeks Ago   #1
Unhappy Tyre Pressure for a 500F with a 126 engine?
Hello,
A simple question hopefully but one I am struggling with!
I have a 500F with a unmodified 652cc engine from a 126, I am running new 125/80 x12 radial tyres.
My 1970's user manual states that the front should be 16 PSI and the rear 23 PSI, as the engine from the 126 is heavier (I presume bigger cylinders alternator etc) what pressures should I be running for front and rear?
Thanks in advance for your help!
Strada Bianche
Strada Bianche is offline Reply With Quote Quote
Old 4 Weeks Ago   #2
Re: Tyre Pressure for a 500F with a 126 engine?
The recommended tyre pressures for a Fiat 126 are:--20psi (F) and 28psi (R)---the 126 is a little heavier overall, so I would suggest that you leave the front 'as is' and take the rear pressures up to 25psi--see how that goes.
Likes Pazzo500, F123C liked this post
the hobbler is offline Reply With Quote Quote
Old 4 Weeks Ago   #3
Where about in the UK are you--there may be a Forum member close to you who has run into this problem and can give you some advice re. his (or her) experience.
Likes Strada Bianche liked this post
Old 4 Weeks Ago   #4
Thanks for the fast response tyres pressures are now where they stood be and looking sweet!
Old 4 Weeks Ago   #5
Hi, I have a Gamine with a 126 engine fitted and found that 15 psi up front and 18-20 on the rear (165x50x13). The Gamine is a lot lighter than a 500 and bounced about a bit with anything higher. I have run this for at least 6 years and the wear pattern on the tyres is even. It took me quite a while to find this solution.
Ralph
thepuddlejumper is offline Reply With Quote Quote
Thread Tools
(T) 126 low fuel pressure aidanfiat600 126 2 06-01-2017 21:49
(T) Speedo cable on 500F with 126 engine mightygeorge 500 (Classic) 3 14-04-2016 14:20
(T) Tyre losing pressure but no issue with tyre / valve austenw90 Punto (2012+) 7 25-10-2014 16:10
(T) fiat 500f 69' - engine swap 126/650cc Phiat500 500 (Classic) 33 05-02-2014 17:13
(G) Tyre pressure for spare tyre Cinquelover Cinquecento / Seicento 2 19-02-2006 23:02
