Murf has had a facelift and like all such surgery this has had a dodgy result.
Having made the decision to fit spotlights, what better mounting than to install the ready-made item from the "L" model? I had to drill two holes at the base of the front panel and I used dome-headed stainless-steel bolts to secure the bar.
I decided that the simplest and most secure fixing for the lights was to drill a hole through the bar at the appropriate points. I haven't got as far as the electrics yet and more modification is likely. The lights look even more odd when viewed from the side so I may buy or make some brackets to allow them to move back closer to the bodywork.
I'm not sure I can get used to the look although it is largely emulating the appearance of some of the rallying 500's I have been admiring recently.
MAL_9700 by Peter Thompson, on Flickr
MAL_9707 by Peter Thompson, on Flickr
