Old 18-07-2019   #31
Re: Faulty Fan/Impotent Impeller
Quote Originally Posted by fiat500 View Post
I assumed you were X with a member over something
Thanks fiat500 thanked for this post
Likes fiat500 liked this post
Bigvtwin996 is offline Reply With Quote Quote
Old 18-07-2019   #32
Patinated Peter
fiat500's Avatar
fiat500 has donated!
Faulty keyboard and brain. I was going to say that in my humble experience, admittedly with a feeble 652 engine and the sub-zero temperatures of Scotland, it is possible to overcool the engine. That would primarily be by omitting the thermostat. I think people don't always realise that the engine doesn't just get up to to working temperature and stay there. As Tom observes, it can drop as the terrain or ground speed changes. You actually want the engine pretty hot, so a good stat will maintain that and avoid overcooling. I don't see why that won't also apply to tuned engines.
Quote Originally Posted by Bigvtwin996 View Post
fiat500 is offline Reply With Quote Quote
Old 21-07-2019   #33
Patinated Peter
fiat500's Avatar
I've removed the securing-nut for the impeller again...it was really secure because I originally used threadlock and it fought me to the end . It turned out that I do have a rubber washer fitted and in theory, everything should be fine. But I find that I can rotate the fan on the shaft by about 5 degrees when loose. There should be no significant movement as it sits on a boss which is tailored to fit the central hole. So this means that either the centre of the fan or the boss or both are worn.
Next step; order a new one....
Old 21-07-2019   #34
What fan you going for Peter! Original or the Alu unit ?
R
Eat French. Dress British. Drive Italian!
1975 - 500R
1987 - 5000 QV
1996 - F355 Spider
2006 - Vauxhall Astra (mule)
lazylobster is offline Reply With Quote Quote
Old 21-07-2019   #35
Patinated Peter
fiat500's Avatar
Quote Originally Posted by lazylobster View Post
R
Don't tell anyone, (especially @Bigvtwin996) , but I have chosen the aluminium version.
The primary reason is that it seems to have a more substantial central fitting area whch will avoid this problem in future; but I am also told that I will have the benefit of increased air-flow and consequently better cooling and, presumably, heating.
I've done quite a few miles with the worn impeller and it had already done an unknown number of miles on another engine. It will be interesting to find out how it compares with regards to noise, balance and the actual cooling function.
***THIS IS NOT A MODIFICATION*** ..(just a service upgrade).
Likes lazylobster liked this post
Old 21-07-2019   #36
I won’t tell a soul
Will you be able to do a before and after airflow measurement?
R
1975 - 500R
1987 - 5000 QV
1996 - F355 Spider
Old 21-07-2019   #37
The Whitakers has donated!
Doesn’t this apply to anything and everything?
500 F
The Whitakers is offline Reply With Quote Quote
Old 21-07-2019   #38
Patinated Peter
fiat500's Avatar
Good question. I haven't seen any stats on this but only anecdotal evidence. I will give some thought as to how I could give a scientific report on airflow improvement.
Old 21-07-2019   #39
Only way I know is via a cfm meter. Seen on amazoooon for less than 20 notes.
R
1975 - 500R
1987 - 5000 QV
1996 - F355 Spider
Old 21-07-2019   #40
Patinated Peter
fiat500's Avatar
R
I was think more along the lines of an A4 sheet of paper flapping in the wind.......
Likes lazylobster, The Whitakers liked this post
(T) Climate Control [faulty fan?] leelee Stilo 93 19-01-2020 13:45
(T) Faulty electric fan (radiator) P dot co dot Punto (Mk2/2b) 18 02-06-2015 09:39
(T) Is faulty body computer the cause of Faulty power steering & broken central locking joimoi289 Punto (Mk2/2b) 14 07-01-2012 15:53
temp gauge faulty +fan not cutting in when it should but is workin HELP scott FIAT Boo Archives 19 15-07-2007 20:35
(T) thermostat or water impeller? loui666 Punto (Mk1) 5 29-05-2006 21:15
