jjacob
Member
Sorry for the long post.
Thought I would start a discussion about oil supply for installation of an oil cooler and/or oil filter. I have some concerns about the usual way to route the oil from the engine.
I am building a mild 650 engine using a later 126 engine with the wasted spark ignition. I really want to install a proper spin-on oil filter. I just think the centrifugal oil filter is antiquated and will never filter oil like a proper oil filter can. I also happen to have an OEM Saab engine oil cooler from my 9000 that I would like to install also.
The original oil path has the oil pickup sending oil through machined passages in the front of the timing cover to the oil pump gears. Oil is pressurized and sent out the hollow shaft of the driven gear into the front of the camshaft where the oil pressure is regulated. It goes from here to the centrifugal oil "filter" and then through the crankshaft, etc.
Most modifications are through the front timing cover. The hollow shaft is plugged and the oil forced to go out through a machined hole in the front cover. Return is to the tapped hole (normally plugged) at the front of the engine case at the 2:00 position which dumps into the camshaft front bearing.
To me this means that the oil pressure is unregulated, especially at start. I have had off forum discussions with Tom (the hobbler) and he said he was told that you need to drill a 2.5mm hole in the oil pump shaft plug so that some oil is bled back to the camshaft/oil pump interface, and that it prevents high cold start oil pressure. Still, to me, this is a compromise.
I realize that lots of people have done this modification and your engines are not exploding. Just looking for some guidance and assurance.
So my options would appear to be:
-Do the modification as most people have done and make sure to drill a 2.5mm hole in the oil pump shaft plug.
-Do not make any modification to the oil pump/timing gear cover. Instead tap into the oil sump and install a separate small electric oil pump as used to scavenge oil from turbos in turbocharged engines. I am leaning toward this method. This is also what Damon500 did.
Only problem I see for me with Damon's oil pump choice is that it is only capable of 0.5 bar (7.2 psi) which is fine for an oil cooler, but is not enough pressure for an oil filter. However, there are other pumps out there that will do 20 psi.
John
Here is a link to that discussion:https://www.fiatforum.com/500-classic/428031-oil-cooler-mod-4.htmlI have been experiencing excessive oil temperature issues in our summer with my Giardiniera and also decided to fit an oil cooler.
In my case I didn't want to add further obstructions into the oil circuit as the lubrication system is marginal in the flat engines and not that easy to upgrade.
My solution has been to use a VDO electric oil pump operated by a temperature switch or the oil pressure light and a cooler mounted under the rear seat.
The pump is mounted low to prime quickly and has a capacity of 160l per hour which should mean that it circulates the entire sump through the cooler within a minute.
I have setup the system to bypass from the sump and return into the oil pump inlet so the system is effectively fail safe. One other advantage with this system is that it still maintains full flow through the cooler at idle when oil pressure is normally at its lowest.
So far the system has worked well and maintains oil pressure at idle and speed even after sustained 100km/h travel in high 30 degree summer temperatures.
John
