timgarman
Established member
Hi folks
A little advice to a novice mechanic here please so don't use any long words.
I'm trying to determine the static timing for the distributor on the pulley for ignition timing. There's an arrow on the engine casing. Should there be a mark on the pulley and if so, is it firing or TDC?
(I will have help so you use some long words if you need to.)
Tim
Tim
