I took Franko to another show today. The Darling Buds of May Classic motor show held in the fields next to the original setting from the series.
It was a great turn out however the fine drizzly rain put a damper on things!
This was Franko's longest run so far about 26 miles each way.
I kept him off the motorway and kept to the A/B roads. He is quite happy driving at 30-45mph.
On the way I noticed a noise coming from the osr wheel. I have heard it before but usually when I am coasting on going round a bend. It disappears when the brakes are used so I presumed it may be a slightly distorted drum.
When I got home I dismantled the rear drum to find its not so much a distorted drum but the edge of the leading shoe is rubbing on the inner face of the drum.
I have checked the original set up and everything is correct including the lower spring inside the lower plate.
I have taken the grinder to the shoe to remove the excess metal thinking maybe the shoe is too wide. reassembled and its still rubbing.
Tried adjusting the lower metal plate to adjust the tension on the lower spring so as not to cause the shoes to pop out so much but still no difference.
Any suggestions before I go ordering a new set of drums & shoes?
The photos show the wear to the outer edge of the leading shoe and also one of the set up when I took the car apart originally.
