jjacob
Member
It does not matter. The rating for the ballast resistor is 1.6 ohms. This would be measured normally at room temperature, but again, it is the value assigned to the resistor.1.6 ohms when hot or both hot/cold?
I have run with voltage measured both on the battery and on the coil with around 14V, so no problems there..
14v is too high for a coil that is not designed for that voltage. A coil designed for that voltage will have a higher internal resistance.
To me it seems strange to add a ballast to a coil that is not designed for it,
There are two types of standard coils. Those with the resistance built in, and those that need an external ballast resistor. The coil manufacturer will state this in the specification for the coil.
Don't remember having this problem on any of my old beetles though..
I had lots of beetles also. There were two types of Bosch coils for the Beetle. One had the ballast resistor built in, the other needed an external resistor.
Shouldn't the coil get twice as hot with twice as many cylinders?
Answer to that is no. Coils are giant condensers. They build and store energy. Typically they will fail in a manner that is noticed at higher rpm as a miss. The coil has lost its capability to build and store the required voltage and can't keep up with the discharge rate at high rpm.
