Old 03-05-2016   #1
Spain
carburettor
Hi All. i have a 500 L with a broken carburettor,it is a 26imb10 can anyone explain the difference between the weber carbs.i have the chance to buy a reasonably priced 28imb 10. would this work? thanks.(or has anyone a 26 for sale?)
El cargador is offline Reply With Quote Quote
Old 03-05-2016   #2
Re: carburettor
The 28 will work fine. Its just a bigger throat. 28mm compared to 26mm
Likes El cargador liked this post
Paolo66 is offline Reply With Quote Quote
Old 04-05-2016   #3
Shed Troglodyte
Bambino's Avatar
Bambino has donated!
Australia
Re: carburettor
Have a look here -
https://www.fiatforum.com/500-classi...26-28-imb.html
Might not answer your question, but may help if rebuilding.
Chris
1967 Fiat 500F (Enzino)
Sundry other Italian rotboxes
Amante di vecchie automobili italiane
Bambino is offline Reply With Quote Quote
Old 04-05-2016   #4
USA
Re: carburettor
Long story short yes you can. There is no need for a 28 IMB unless you want to go with bigger pistons.
If you choose the 28 IMB, you will have to either block off the return line from the carb or make a t-line to dump residule gas back into the system. Reason is, the 28 IMB was designed for the Fiat 126 and it had a return fuel line from the carb to the tank. The 500 L does not have this feature.
Luxe is offline Reply With Quote Quote
Old 04-05-2016   #5
Re: carburettor
I also have a 26imb surplus to requirements should you need it although you should be able to source one locally
Old 04-05-2016   #6
Spain
Re: carburettor
hello Paolo i am in Spain. fiat 500 are rarer than hens teeth here.how much do you want for the carb?
Old 04-05-2016   #7
Spain
Re: carburettor
would the carb from a Seat 600 be the same?
Old 04-05-2016   #8
USA
Re: carburettor
So that would be a 28M30. Not sure how all the linkage would fit, especially the choke, but most of all I am not sure the base would match up right.
Old 04-05-2016   #9
Re: carburettor
On the Weber 28M30 carburetor, the base looks very similar in size, but the throttle linkage is on the wrong side vis-a-vie the mixture screw. If you have easy access to the mixture screw, the throttle linkage is at the FRONT of the engine, so you would have to redesign the linkage. It is also a bit taller than the 26/28imb, so you would have to do a bit of head scratching regarding the inlet filter or trumpet---a short S.U. trumpet with the mounting plate removed might do the job.
the hobbler is offline Reply With Quote Quote
Old 05-05-2016   #10
Spain
Re: carburettor
thanks for all your help.i got a good deal on a carb in Italy for 30€.
Likes Paolo66 liked this post
uno 1.4 carburettor Ramesh Mahabeer Tech Talk 1 03-03-2012 03:47
(T) Carburettor over heating pandamonius_maximus Panda (Classic) 14 16-07-2011 15:36
(T) Carburettor help please nerodino 500 (Classic) 6 07-08-2010 15:48
(G) Carburettor Robot Ducato 0 25-07-2007 09:13
(T) 1.6 Carburettor Trancendental Tipo (Classic) 0 10-01-2006 03:09
