Old 15-08-2016   #46
Fast, and from Australia!
enzothe500's Avatar
enzothe500 has donated!
Australia
Re: Enzo the Cinquecento - RestoMod
I picked up some parts from the powdercoaters yesterday.
Original Logotech/Wheeltech 12x5.5 +18 wheels. These are no longer available and I contacted the manufacturer to see if they knew where I could get some. They had a set sitting in storage that didn't pass quality control back when they were manufactured due to poor painting. I got them for a very good price, got them x-rayed at an NDT lab, then zinc-coated, and powder coated "Gold Tarnish". They look brand new and will look great on the finished car!
I also had the voltage regulator cover re-done too. In a hi-temp black powder coating. Looks very good, but also shows a bit of it's age with a slight wear on the letter/numbering, which I'm really happy with.
There was evidence of at least one engine fire prior to the one I had when I first got the car, so this cover was an absolute mess beforehand.
ID:	170508   Click image for larger version
1970 FIAT 500L 110F LHD, 650cc | Sydney, Australia
Connect with me on social media:
https://www.facebook.com/EnzoThe500/ | https://www.instagram.com/enzothe500/
enzothe500 is offline Reply With Quote Quote
Old 15-08-2016   #47
Re: Enzo the Cinquecento - 500L 110F RestoMod
Nice rims....
AndrewHarvey is offline Reply With Quote Quote
Old 16-08-2016   #48
stevehg has donated!
Agree, they look good. So Axel Gerstl has stopped selling them I take it. That's a shame.
btw - not sure that an X-ray on a steel would have been very productive. I've always found a lump hammer corrects any problems with a steel wheel.
stevehg is offline Reply With Quote Quote
Old 16-08-2016   #49
enzothe500's Avatar
Australia
Quote Originally Posted by stevehg View Post
Yes, AG don't have new stock but did help me source this set.
I had to X-Ray to check the welds as the wheels had failed quality control at the factory in the past. Structurally they were ok, however they needed to be completely stripped and recoated so I could do a visual inspection too.
Old 17-08-2016   #50
enzothe500's Avatar
Australia
More progress shots.
Nowhere in Australia stocked the screw-on flange required to mount a Monza-type filler cap, so we went with something retro race car instead.
Picture doesn't show final filler location. The filler will be dead center of the tank, with breather and pick-up lines routed to the back. Steel straps wrapped in rubber will be mounted using existing tank tabs.
VDO tube-type fuel sender unit will be installed driver-side front corner.
Breather pipe will be routed through the drain hole at the base of the A-pillar.
Pick-up bag in baffled swirl pot, and rest of tank will be foam-filled.
Tank is aluminum and will be finished in a longitudinal brushed scotch-brite.
Final seat-fitting completed, whilst lowering steering rack slightly, we re-centered the wheel to the new seating position. I'm 6ft1 (183cm) tall and I have perfect arm position now, clear line of sight to instrument cluster, and about 4.5-inches of head-room.
The anchor points for existing/original seat belts have been integrated into new tether points for the floor-mounts, and using the existing mount on the b-pillar.
Bar-work now sent off to powdercoaters to be finished in satin black.
Old 31-10-2016   #51
enzothe500's Avatar
Australia
So there has not been much progress. I am still renovating my unit (very slowly) and therefore my little FIAT has not had much love. During the final install of the bucket seats we stripped back the floor tar to do a final check of the body and found some bad rust. To have it at this point and not fix it would be silly, so we cut out the sections, welded in some new fabricated channels to match, and gave it a hit of primer.
The footwell area located just along the door will and adjacent to the wheel arch.
Paper weights, anyone?
The new fabricated piece
Welded in place with a shot of primer
A good match to the original I think.
The underside re-done with stone guard
I have tiling, painting, and carpet going in next 2 weeks, and then I can move all my furniture back upstairs and have a garage back. Only 7 weeks until I need it for my wedding.
Cue the mission impossible music.....
Likes dk500 liked this post
Old 04-11-2016   #52
enzothe500's Avatar
Australia
Interior bar-work back from the powdercoaters and installed. Upper pick-up points for original seat belts have been retained; bolted in with bars.
Petrol tank nearly complete. VDO fuel-sender unit installed, central baffle chamber, fuel pick-up Matt, and full foam fill. 34.9L capacity!
Just need to install the Aeow plumbing up to the old fuel line.
Old 05-11-2016   #53
Try 'Holden Vintage and Classic' (www.holden.co.uk) --they do a 'Monza' style fuel filler-cap (part numbers:- 015.184/015.181/015.185/015.182) They may be able to help you out as per the required flange--the thread size of which is 2" or 2-1/2" (depending on the size of filler cap) 16TPI.
Likes enzothe500 liked this post
the hobbler is offline Reply With Quote Quote
Old 06-11-2016   #54
Australia
Quote Originally Posted by the hobbler View Post
I used them to get door handles etc for my Austin7 delivered to Australia
Very good service.
1500500 is offline Reply With Quote Quote
Old 29-11-2016   #55
enzothe500's Avatar
Australia
Seats and bars finally installed.
Fuel tank plumbed in, new hard lines front to back.
Engine bay stripped of all old tar and matting, re-sprayed with pressure pack for now.
Old 27-08-2018   #56
Australia
Quote Originally Posted by enzothe500 View Post
Attachment 174007
Attachment 174008
Attachment 174009
Attachment 174010
Attachment 174011
Just saw your Post re 3D printers.
How is the resto coming along?
Old 28-08-2018   #57
enzothe500's Avatar
Australia
Sadly it's all but stalled. A combination of renovating my (small) apartment, having my first child (18 months ago), and running my own business has meant all of my free time has been taken up. I am trying to clean up my garage at the moment with a view to get things back on track at some point later this year.
I have been knocking off very minor design jobs, and spending a lot of time over-thinking ways to do things, so hopefully when i get time to work on it i can just start ticking things off the list.
Old 29-08-2018   #58
Australia
That sounds like my Austin 7 resto story . Took 8 years in the end but was worth it...
Old 30-08-2018   #59
enzothe500's Avatar
Australia
Quote Originally Posted by 1500500 View Post
Right. Should probably flush the engine and cryo-seal it for thawing out in 6-years time then!
Old 30-08-2018   #60
Australia
Not quite. Like you I spent a lot of time thinking things over and doing small jobs every now and again.
Eventually it all adds up to a finished car.
500 Enzo. Littala Members Motors 20 29-02-2012 20:57
(G) Enzo's nearly here.. kathryn 500 4 06-04-2009 12:17
O/T Enzo anyone?? Kate FIAT Boo Archives 4 16-09-2006 02:41
